Scanning using a Mac for a PDF file stopped working. Need help.
CA, USA
I always (or years) used the System Preferences -> Printers and Scanners to scan documents to PDF (text, B&W or color) using my Brother multifunction printer. All of a sudden, when I try to scan to PDF the attached file is what I get. When I use B&W or color to scan to JPG, the scan works correctly but I need PDF. I reset the printer to factory settings, reset the printing system and re-added the printer, downloaded the latest driver utilities from Brother, and even erased my MacPro late 2013, 32GB RAM and reinstalled the OS (Mojave) but the problem still exists.
I can't explain why what once worked now doesn't, but could you print the .JPG and on the print window select "Save as PDF" or alternately open/edit the .JPG with preview and then "file" > "Export" > "Export as PDF"
