Scag hydro oil
Indiana
I have a zero turn Scag STC52V-22FX with 83hrs. I want to change the hydro oil mainly because the cap came off while I mowed and I don't know if any debris got in tank. The owners manual calls for SAE 20w50 motor oil. Has Hydro-Gear BDP-10A-316 pump with Parker drive motors. I chose Shell Rotella T 10w30 Heavy Duty Conventional Motor Oil for the motor with a Wix filter but Shell Rotella doesn't make a SAE 20w50. Whats the oil to use do you think.
I've been using Mobil 1 15W-50 in my Hydro-Gear G730. It is spec'd for 20W-50 but 15W-50 runs just fine and with the Mobil 1 rebate it only costs about $11 for 5 quarts.
My Scag STT owner's manual just calls for a "20W-50 motor oil" and does not specify any API Service Category, so presumably any 20W-50 from API SA through SN would be acceptable. That said I would stick with current API Categories such as SL, SM, or SN and definitely avoid the old obsolete categories. I also would not hesitate to use a 15W-50 synthetic such as M1.
What is equally confusing is the fill level specified in the manual. My manual says the "Hydraulic oil must be at least 3 1/4" from the top of the filler neck." Well 12" is at least 3 1/4" from the top of the filler neck, but then the sump would be empty. I suspect they meant to say no more than 3 1/4" from the top of the filler neck, but then that includes filling to the brim. I just fill mine to exactly 3 1/4" from the neck.
Tom NJ
I have also used Mobil 1 15w50 in my Gravely's Hydro Gear ZT-2800. Basically 15w50 full synthetic is a direct replacement to conventional 20w50. Your pump or motor probably like that the oil is a little thinner when cold.
Yesterday went to my scag dealer, which I like he's great.I asked what they use in the hydro all he said was what ever is on sale. He didn't have a filter so I'm just going to top it off with a conventional 20w50 till I get a filter. I'll definitely check out the Mobil 1 15w50. I stopped at Autozone, Oreillys,and Advanced on the way home looking for a conventional 20w50 but didn't see anything I liked, was really limited. Can you put Mobil 15w50 in with whatever I have in the tank that was on sale? lol
Check out Walmart. the one by me always has a selection of conventional 20W-50. I would not waste using Mobil 1 15W-50 as "add oil" to what's in there. Save the Mobil 1 for when you get the filter and do a complete oil change.
Whimsey
I went with a case of Havoline 20w50 after talking to three different dealers I found that one was 15w40 synthetic and the others were whatever conventional was cheap. I just topped off my tank so that I could mow. Kind of surprised that there is no standard to what goes in a brand new scag that cost $80000.00 dollars. Whatever I guess I'm not very pleased. You know I just want to do what is correct and I believe that scag should say If your a dealer use this cause we tested it and know it's good. Which may have been the case with saying use any SAE 20w50 conventional motor oils.
Hello RedEyedRooster, since your OEM Manual recommends a 20W-50 viscosity grade motor oil, we recommend you stay with that viscosity grade since it is critical to the long-term protection of your engine). The Shell Rotella T 10W30 Heavy Duty Conventional motor oil you mentioned is a much thinner viscosity grade than your OEM requiries so we would recomend making the switch to Pennzoil 20w-50 Conventional motor oil (Pennzoil conventional). Hope this helps! - The Pennzoil Team
