Greetings
I am new to the site. Could I get some guidance on which ATF Brand of DEX MERC III to use in my 2001 Saturn L300? It has the Ecotech 3.0L motor. I bought this used with 230k miles. It runs well and shifts well. I did the fluid level overflow check and there is an adequate supply now, but the oil is not Red, it is a shade below this, somewhat dirty and darker than a bright red one would see in fresh ATF. I would like to pull the pan, change the filter and flush the ATF system with 10 quarts minimum. I would like to use the best economy oil. Is there any comparative data on ATF brands?
