Wife's 96 Saturn SL2 - dual cam engine. Engine seems to run fine, starts fine but the engine check light comes on occasionally. Here's the print out from Auto Zone:
Cam sensor condition
Explanation:
The camshaft position sensor signal is monitored for errors.
Probable cause:
1. Cam sensor defective (there's not one on the car according to AZ)
2. Check connector and wiring to sensor
3. Engine mechanical condition-timing belt/chain out of time.
4. Cylinder misfire - Check ignition system for faults-plugs, wires, coils.
I replaced the plugs about a year ago. Car only has 45K on it.
Any ideas where to start?
Explanation:
Probable cause:
