Which Thermostat to use oriellys calls for 185 autozone Is 180 and people online say 195 . Apparently saturns have issues with colder stats? Can some one educate me on this.
Computer wont go into "closed loop" until engine temp is X amount.A cooler thermostat will take longer for an engine to heat up.Wasting fuel,causing excessive cylinder washdown,and shortening cat con life.
Sure.
You for sure want to use a Stant thermostat in the Saturns. If you have a regular Saturn, it's P/N 14279.
It'll say 188 on the box and that is the opening temp. It's fully open at 195.
That will work, although I prefer the actual thermostat replacements, not the entire tube with builtin thermostat.
I've used OEM, Napa, and Stant thermostats on my 1.9 Saturns all with success.
Yes, issues with colder thermostats.
Get a Stant at NAPA, etc.
Make sure the Temp needle is at least 2 needle widths above the 1/4 mark. If not, change your ECTS (Engine Coolant Temp Sensor) as they are well known to get cracked, especially the old polymer one.
Two Saturn musts: A Stant thermostat + a new ECTS.
What kind of issues? Right now it runs about 1 needle thickness above 1/4. Is there a way to post a picture on here I can show you exactly where it runs.
That is too cold.
Just replace the stat and you'll be golden.
Well it says it meets oe specs. Could I return it and get a hotter one? I really don't want to buy another . 14 bucks for a Thermostat is kind of ridiculous.
Get the hottest one you can, 195 it should be. The rubber tip is a wear item that leads to bypassing and cold performance after a couple years; get something with a good warranty and you're golden, save for the labor.
I recall reading some saturn's (all?) having head, headgasket, etc. problems...I'd go with an OEM...or a SuperStat from STANT if there is one available.
Check rockauto.com they usually have a good list of products available....
185 is honestly fine... I ran a 185 in my SL1 and it was good. The OEM stat had been running too cold for a long time and with the new one, the gauge read 3/8 (proper for 96 and up) and had good heat, with a dealer 185 thermostat. You are worrying too much, just get a good one and replace it.
Napa
OEM
Stant
Done
