Sam’s Battery test question
USA
I have a Sam's club Duracell 65 series made by East Penn. occasionally I get a low battery warning on my radio. I have a Noco Genius battery charger 3500 that I have used to help charge it up, but it never gets to 100% charge where the green light should go solid. I had an auto parts store do a test, and sams did a midtronics test showing 795 out of 850 CCA with a battery temp of 89 degrees F on a 28 degree day. The voltage showed 12.4 which I think is kind of low. Is this normal for an 8 month old battery? Alternator tests good as well. Both tests passed.
maybe not but charging in cold weather is harder for some chargers + likely it will test lower. my C-tech 4.3 MUS has a cold weather charging setting for 40F + lower. read where after a charger shows good shut it off a bit + reconnect + you will see a lower level. winter driving with everything on + especially todays stop-start is hard keeping a battery up unless you do long drives or use a charger frequently IMO
That makes sense. I use the cold weather setting and had a long drive a couple days before testing as well as frequent charging.
Battery temp of 89 on a 28 degree day? Huh?
That to me says that the battery has high internal resistance, though their cca value implies otherwise.
12.4 is too low for a disconnect3d, fully charged battery.
12.4 is low, should be (at least) 12.6 when fully charged. Might be working on a weak cell, a hydrometer might tell you more, IF the battery cell caps are removable. I think I would try for a warranty replacement.
I was hoping for a warranty replacement, but without a bad test I'm out of luck. The battery does not appear to have any open caps. It's a flat type of no maint one made by east penn.
This happened to me recently. I have a duralast gold in my truck that is chronically showing 12.4 no matter what. It starts the truck but theres some strain to my ear. Autozone tested it as good. I think its marginal.
Same thing I'm tracking on my truck with an autocraft silver battery. Another JCI variant fwiw.
For general awareness, the value of 12.63V indicating 100%SOC is specific to a 77F "standard" condition.
The 100% SOC value varies with temperature, and is lower when colder (eg 100% at 27F is 12.53), and higher when hotter (e.g. 100% at 87F is 12.65).
If the Walmart tester didn't measure a suitable SOC for their identified internal temperature (iirc OP stated 89F), then it should have at least raised a flag of the need to charge it.
That's what is so surprising. Both times the battery had been charged one way or another. I looked at the temperature charts and knew the voltage was low. I thought the auto parts place I didn't buy from might have failed it. I have bought batteries at that store too.
