Is it safe for my family to drive in my 98 1mzfe toyota avalon on a cross country trip with a rear exhaust manifold crack? The crack is large enough to where we can smell exhaust in the car IF AND ONLY IF we have the fan on set to "outside air" (the rear exhaust manifold is just below the outside air intake). If we use "recirculating air" with the AC or heat on full blast, even my wife (with a very sensitive sense of smell) cannot smell anything in the car.
I have installed a chemical CO (carbon monoxide) detector (the Pro-Lab CA101 Carbon Monoxide Test Kit) in the car, and it shows nothing when I drive around all day. It is pretty sensitive for detecting CO at low levels.
In about 15 months we will get a perfect car from a family member who lives in the rust-free south, so we do not want to buy another car just yet. The avalon runs great and is comfortable on long road trips. Except for the manifold crack, it is in tip-top shape. I do not want to fix the crack for a number of reasons. The bolts are very rusted (driving in the rustbelt for 19 years), and I'd probably crack a couple in the head for sure. I took it to two mechanics and they said the same: they could fix it for about $1200 if no bolt snapped, but if a bolt snapped then it could get very expensive. It is really tight down there and the head might need removal if it snapped. I just did an Aisin kit for all the seals, belts, and water pump last year. It has 210k miles on it.
We will drive an 8 day road trip with the kids this summer (4 4-hour days each way).
Do you think this is safe with the exhaust manifold leak? Right now the kids have been limited to being in the car about 15 minutes max with this leak. I'm wondering if it is a good idea to spend so much time in the car, even though there is no smell and the CO chemical detector (which is supposed to be far more sensitive than an electronic in-home CO detector) does not detect anything.
