Originally Posted by kschachn
Originally Posted by fleetwood62
kschachn, Shannow, So are you saying that 30W would be equivalent to the 20W of old? So maybe use a 5W30 non-detergent? Thanks for your interest.
One needs to be a bit more careful on the nomenclature, the "W" rating of the oil such as 20W or 5W is largely irrelevant here unless you are operating the car in cold temperatures. Even if you aren't then a winter (W) rating of 5W or 0W is not going to make any difference. The grade of the oil is the number after the dash and what determines operating viscosity. If it is true that a 20W-20 has an HTHS of 2.9 or so, that is near 3.0 which is where many 30-grade oils live. So yes, a 5w30 (a 30 grade) looks appropriate for your vehicle - or a 10w30 depending on whether you plan to operate at or below 0F.
As I mentioned before and as MolaKule confirmed there is no reason to run an ND oil, only downsides. Especially with no or ineffective filtration the additives in the oil will help to keep contaminates in suspension rather than settling out.
Why not just order a case of the Citgo "straight" 20 (20w-20) and use that? We talk a lot about the HTHS vis in the context of modern pressure-oiled vehicles always using multi-grade oils, that almost always contain substantial amounts of vis index improvers. I'm not so sure that HTHS is relevant for this engine. Remember, it's not pressure oiled like a modern engine. It uses that odd (from today's perspective) sprayer and dipper set up to deliver oil. I'm not an engineer, but I have read suggestions that this method of oil delivery may be relying upon the lower viscosity of the oil to properly deliver it, via the "dippers" to the bearings. With that in mind, no matter the HTHS values, might the 100C centiStoke value be more relevant? The Citgo 20w-20 "straight" listed in the linked chart, earlier in thread, is 9.0 cSt at 100C. Their 30wt is 12.0 cSt. The modern Xw-30 oils will be similarly "thicker." The OP noted that the engine seemed to idle better using 20 wt oil. There may be something to that. As suggested already, I would check with one of those shops/experts who actually works with engines of this type (splash/dip non-pressurized oiling) to get a better informed oil vis recommendation.
