I changed the rear brakes in my wife's 9-3 yesterday. These use an unusual caliper piston which must be compressed, then turned, then compressed again, then turned again, etc. to retract. NOT EASY!
I bought an OTC caliper tool, and purchased the correct piston adaptor from Assenmacher Specialty Tools.
The trick was to compress the piston, then release it slightly to turn the piston, then compress it again. The passenger side piston, the first one I attempted, was stuck pretty bad too. That one required a LOT of time whereas the driver's side was not too bad. I still spent six hours doing what I thought would be a two hour job.
