Hello BITOG crew!
Recently purchased a 2000 S2000 (AP1) with the F20C 2.0L 8,800 RPM engine in it. Car has 129K on it and will be used as a track toy and street go-cart. Will not see cold weather usage.
The car is specced for a conventional 10w30 from Honda. Previous owner ran Amsoil 10w-40 in the engine, Amsoil MTF in the trans, and Amsoil 75w-90 in the rear axle. The hot oil pressure at idle is 32-36psi, and at 3,000rpm is at 83psi. The spec calls for 35psi & 85psi respectively. To me, it sounds like a 40 grade oil is appropriate, would you agree?
Amsoil 10w-40 is expensive compared to what I would normally run. Could I switch to a 0w-40 oil, perhaps the same as what I run in my German cars?
Any recommendations for the trans or diff? Honda of America Racing Team runs Redline - I was thinking of trying that.
