Anyone with an older Chevy truck knows about this problem.
This is just an update. 2.5 years ago, I cut the rust out with tin snips and hack saw blade. Treated with phosphoric acid/zinc oxide solution, and two coats POR-15.
But now I had GAPING holes in body about 2' x 3'!! I cut some aluminum sheets to size, and used two part epoxy to secure them to the body. Yes, epoxy. Truck has been through 2 winters. Panels still holding tight.
Last night I went over rocker areas again with Rustoleum truck bed liner...just to freshen her up a bit.
Doesn't look too bad for a 24 year old 3/4 ton 4x4 $2000 truck, huh?
She just got new shoes, new shocks, and front end completely rebuilt.
