No, no, no, no, no, no, no... I was referring to the possibility of too much water in the mix - which would result in less than a 50% glycol concentration. For goodness sake, get one of the Prestone or Victor pointer-type antifreeze testers and check your glycol concentration, and adjust as needed. I'm concerned about the corrosion at the radiator cap. Something's still wrong. If the coolant level isn't right up to the bottom ring of the radiator cap opening when cold, you have to find out where the coolant's going. If you're lucky enough to have a radiator cap on the radiator itself (I believe most ChryCorp products now have the pressure cap on the pressurized plastic overflow tank - someone correct me if that's wrong.) check the condition of the visible radiator core compenents - if there's scale present at the core tube openings you're able to view, you got corrosion problems whether your car's oveheating yet or not.
[ September 12, 2005, 11:42 AM: Message edited by: Ray H ]
