Running less oil (Winter months)
It is an interesting idea, kind of the reverse of running extra oil in summer. I run my Aerostar 3.0 about 12 oz above the full mark, which is a total fill of 4.75 qts using an oversized filter (FL1A). If I ran it a quart low it would still have 12 oz over the bottom of the fill area (hatchured area of stick), so unless you never check the oil, there is a margin of safety. Also this Aerostar has a low oil light.
The real question is whether it does any good. Less oil, the oil should warm up faster. We know that the engine can be at operating water temperature long before the oil is to full operating temperature, so there may be some benefit to his, although running a thinner oil should achieve the same, or similar effect. This (running a quart low in winter) may be an option for someone who does not want to run something as thin as a 5w20 in their vehicle.
As for me, I am leaving well enough alone and will run the same level winter and summer.
I don't think it matters much. One would reason that ambient temp would radically alter time to temp numbers ..but it doesn't seem to work out that way in my observations. That is, even a 30-40F difference doesn't alter the curve too much ..just the peak temp by a minor degree.
I was going to test this theory by using thermostats on my minivan. I couldn't reduce a 5 quart to a 2 quart for warm up ..but I could see if I could get a 10 quart to warm up as fast as a 5 quart. The Permacool thermostats have a fail safe leak point (min opening) ..and I was about to put two EaBP110's in parallel to inhibit oil flow until visc dropped ..but that never occurred. Right now I don't have a vehicle to test it on where I can plug in and unplug these types of installations (ample space).
I think Curious Kid suggested this a long way back. A sequestered operating sump and a 2 quart warm up sump.
This is silly. Using a partial radiator grille block and a oil pan heater would be a much better idea and no real risk involved if the the rad block was conservative. Using less oil to me just is risky, especially if your engine uses any amount of oil, you just removed your buffer.
No risk if he adds Slick 50. Didn't they show a commercial where Sick 50 was in an engine and they drained the oil and the engine ran for at least a half hour with no problems?
There was someone on this site a while ago who used to mention that he had a 1970's VW Rabbit that he ran with the oil just touching the end of the dipstick all the time. He used 20W-50 oil, and used the car for pizza delivery. Apparantly, the car rusted out at something like 280k miles, running perfectly.
FWIW....
