RP HPS 5w30 VOA
Southern IN / North central, KY
Here is the VOA i promised of the RP HPS 5w30. Bottle wash shaken well before I took a sample. This oil looks stout.
A healthy dose of Calcium, and plenty of Zink and Phos. Does anyone know if this moly would be Trinuclear?
Enjoy!
Originally Posted By: aquariuscsm
I'd use RP HPS in a heartbeat if I still had my connection.
it can be had cheap when pepboys has sales. Right now you can get 30% off by ordering online. That makes it $7 a qt.
I purchased this from pepboys last month during their 35% off online sale. It's a stout oil for $6.50 a Qt.
I got spoiled buying RP for $40 per 12 quart case
Look really good.. Pep Boys where I am at has it but its not the HPS version. This may be a foolish question.. But, since it only meets API SL than would it could this pose a problem with a car specd for API SM?? And yes I read on the label it is not officially licensed by the API for SL really either..Now my car does NOT burn any oil at through 6500 miles. I know this is a big help due to it not fouling up the cat.
RP claims it is cat safe. SL is only one spec older than SM. I don't think you would have a problem. Im Going to run it in my 08 that was originally spec'd SM.
You can get the HPS version online. They run promo sales often. usually 25-35% off any online orders over $50-60.
I wouldn't pay full price for the oil, personally.
Yeah I pretty much agree with you on that
Really only difference is formulations between SL and SM. And SL likely allowed for higher amounts of antiwear additives. The Synerlec in this version of RP is very good from all that I've read about it
Yeah buying it online is the way to go for sure.
I don't know how they can call it an SL oil. The limit for Phosphorous content in SJ and SL is 1000ppm, and Blackstone measured 1096ppm on this stuff.
HPS doesn't really have any API rating. The old API line was SL, but they jumped to SN, and the HPS has no API markings. It looks from VOAs and used oil analysis that it might be a little more stout in AW compounds than the older API SL line.
Garak, do you see any issue with running this oil in An SM application that does not use much oil? According to RP it is cat safe in mechanically sound vehicles. would you agree?
