This week I switched to Royal Purple engine oil and love it. I can tell a difference in my engine performance already!! I own a 1995 Ford Explorer V6 auto transmission 4x4 with overdrive. I am very seriously considering changing my transmission fluid and differential grease over to Royal Purple as well. The vehicle has 251,000 miles on it and since I do sales during the week and also work a weekend job, it is on the road and runs 7 days a week. The vehicle is generally in good mechanical condition. I do have a problem with the OD light coming on and staying on for several days then it just goes back off. During the time it is on the transmission shifts hard. And just as mysteriously as it comes on, it goes off.
Royal Purple’s Kyle Neal has recommended the following products for my trans and diff.
Transmission- Automatic- RP Max ATF 9.5 quarts You can now double your transmission changes when you switch over to RP Max ATF.
Differential- Max Gear 75w90 2.75 quarts This can be changed at 50,000- 60,000 miles instead of the 15,000- 20,000 mile factory recommendation.
I would like any comments I could get from users of these products. Before and after pluses and negatives. Problems before, or after. Was the results users saw improvements or did the product complicate or increase problems? Would YOU recommend the switch or would you stay with Ford factory products? Please any and all comments are welcome to help me with this decision.
