Royal Purple says this about Castrol Edge
Michigan
From their FAQ section
The Sequence IVA test is an industry bench test that is used to test oils for API licensing purposes. Some portray this as a sound methodology for predicting wear protection. We believe the ASTM D-2782 Timken Load Test is a better methodology for predicting wear because the Timken test actually measures a lubricant’s film strength (its ability withstand the effects of load, speed and temperature without breaking down and allowing metal to metal contact). Royal Purple has dramatically higher film strength versus competing lubricants. For instance, Royal Purple has nearly 6 times the film strength of Castrol Edge®.
• Royal Purple film strength = 113,839 psi
• Castrol Edge® film strength = 18,979 psi
Wow, I'm disappointed in their answer. So an actual ASTM test that uses tear downs to measure wear is not a good test? Ok.
Where's Neo with some Falex test figures, their 0W-5 will blow RP out of the water
Love the spin, and with a shrinking market and revenues it's only going to get worse.....
This doesn't mean however that Edge will protect better than Royal Purple. Again, it's ONE ASTM test. It's also a test that is more about stop/go driving than high performance. Keep that in mind.
RP's response is comical.
Quote:
Though Timken no longer manufactures the test machine, Timken OK Loads are still listed on grease and oil property charts. It was once generally assumed that the measure and the film strength of the lubricant were directly related. Today, the primary purpose of the test is to determine whether EP additives are present and functioning. A measure of 35 pounds-force (16 kilograms-force or 155 newtons) or more means that EP additives are present and working.
From wiki.
I'm not saying that. I'm just saying RP (and other oil companies)get a fat one down the middle....and the response is weak. You have dished up an excellent response, btw.
Originally Posted By: Colt
Royal Purple would be one of the last brands of synthetic oil I would use.
Just on top of Super Tech.
Why's that? I'm not a brand apologist and I've never used RP in an engine, so I'm just curious to what objective measurements make you say that. Granted, their love of the Timken "test" is bothersome, but other evidence? used oil analysis? VOAs?
http://lmgtfy.com/?q=RP+UOA+site:bobistheoilguy.com
Originally Posted By: firemachine69
Originally Posted By: Oily_McOilenson
I use only Clorox in my engine.
Does that count as a flush, or a snake oil?
It gets the white metals whiter
