Originally Posted By: deven
I can get Motul for less than RP, AMSOIL, Mobil 1, PU.....etc up here and I KNOW it is majority PAO because it is sold as full synthetic in Germany.
Various Mobil products are also majority PAO (their EP 0w-20, Mobil 1 0w-40 now again) and yet their prices are the same as their other lubes that have higher group III content.
Other than conversations with marketing folk, what proof do we have that the entire API line of Royal Purple products are majority PAO? Their MSDS sheets are useless and their PDS isn't much better.
Also:
http://www.royalpurpleconsumer.com/wp-content/uploads/PS_API_MotorOIl.pdf
Their 0w-20 has an MRV of 34,200cP. That's higher than Mobil 1 0w-40!!! LOL (31,000cP):
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx
And MASSIVELY heavier than competing Mobil products like the AFE 0w-20, which has an MRV of only 9,200cP:
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil 1_0W-20.aspx
Which does NOT point to a majority PAO base, nor does the fact that despite its poor cold temperature performance, it still has a lower flash point than the Mobil 1 Advanced Fuel Economy 0w-20 product (420F vs 435F) which is approximately 30% PAO based (verified by MSDS)
So I think you can perhaps now begin to understand the skepticism some of us have regarding people stating their API line of products is PAO-based just because some marketing jockey said this might be the case.
Now from that same PDS, you'll note their 0w-40 has MUCH better specs. An MRV of 20,000cP and a flash point of 465F. THAT would point to this product being potentially majority PAO based. So perhaps, like Mobil and Castrol, SOME of the RP products are majority PAO. SOME of the products are not
You'll see a similar trend if you compare the 5w30 to the 5w-40; the 5w-40 has better cold temperature performance pointing to better base stocks.
I Understand your point but until there are baseline data points which clearly state that this number or that number makes an oil Grp. III or PAO or POE, to me they shall remain numbers. And to compare MRV, CCS or whatever numbers are doing so blindly because there are no guidelines. An oil that has poor data points to another may just perform much better INSIDE an engine because neither you nor I know the WHOLE picture of a formulated oil. Going on numbers alone is foolish.
OVERKILL is right here. Easy to see Royal P is thicker than Mobil 1 when very cold. If you live in a cold climate, not sure RP is the best.
Also:
