This synthetic gear oil around these parts is less than Mobil synthetic per quart. I wonder what Timken load it takes?I would think 70 or so ? I have not been able to find that out so far. Here is some info:
Max-Gear® Exclusive Performance Advantages:
Severe Service Performance
Max-Gear® exceeds Eaton’s stringent GL-5 / MIL-L-2105D Gear Oil Specs. Max-Gear® also is safe for GL-4 applications or bronze synchro gears.
Lower Coefficient of Friction
Max-Gear® saves energy, reduces temperatures and maximizes power throughput. (OEM or aftermarket limited slip additives are not required.)
High Temperature Performance
Max-Gear® eliminates harmful deposits and extends oil drain intervals. Low Temperature Fluidity
Max-Gear® meets operating requirements for vehicles operating in cold climates.
Shock Load Protection
Max-Gear® reduces fatigue failures in bearings and gears.
Prevents Corrosion
Max-Gear® protects both ferrous and nonferrous metals during operation and shutdown.
Excellent Water Separation
Max-Gear® completely separates from water, preventing an oil-water emulsion.
Compatible with Other Oils
Max-Gear® is compatible with other mineral gears oils and other synthetic hydrocarbon gear
oils.
Meets Warranty Requirements
Max-Gear® exceeds OEM warranty requirements for GL-5 automotive rear axle hypoid gear lubrication.
Environmentally Responsible
Max-Gear® components are TSCA listed and meet EPA, RCRA and OSHA requirements. Max- Gear® extends oil drain intervals, eliminates premature oil changes, decreases the amount of oil purchased and disposed of and conserves energy.
75W90, 75W140, 85W140
80W90, SAE 90
Prevents Corrosion
oils.
80W90, SAE 90
