Found part of the #3 oil cooling jet squirter clinging to the magnetic drain plug. Found an OEM one and replaced the squirter. You can just see the #2 squirter between the #2 journal bearing cap bolt and oil pump body. Bit of a fiddly job keeping the two crush washers and jet together and lined up and bolt threaded way up the block, but not too bad, worst part was the razor sharp edge of the lower face of the engine block.
Engine only has ~4K miles on it, but the fracture face looked old so who knows. The jets do have occasionally have to be bent slightly to clear rotating parts, and this one had some plier marks on it, so the crack probably originated long ago.
Nothing too exciting, but a good look at an unusual engine for the 'States.
