rough riding tires?
You'll get 0.16" or so (about 5/32, half typical tread depth) extra sidewall. For more comfort, you'd be better off to look at tires optimized for comfort. Tirerack only shows 3 tires in 215/70-17 as well. 225/65-17 is very popular. For snow traction, look at (yeah, I'm a broken record, sorry) tires optimized for that. Tirerack will have comparisons where you can see many advantages and disadvantages of different product.
You did the math - I was scratching my head at the same thing and agree. The change from 225/65-17 to 215/70-17 basically keeps the same sidewall height for a skinnier tread patch. It might still be a ride improvement because of the longer, skinnier tread patch, but not from sidewall height. A possible detractor is the sidewall might also become more straight with less curve (“pooch?”) to flex, if that makes a difference. I’d think something like 225/70r16 might have better results… double check my guesswork with a specs chart or maths to make sure that’s right. In my opinion, 70 series starts riding like a softer vehicle with a more traditional, “average” steering response…
Yes, I play around with Tire Rack comparisons every now and then. I'm just south of Houston so I don't have to worry about snow performance.
225/70-16 would definitely be a good choice but I'm told 17's are the smallest that will clear the brakes so 16's aren't an option. I'll research it more when I eventually get to the point of replacement.
This^^^^^^^^. The more sidewall between the rim and the road, the softer the ride. ex. I prefer the 65 aspect ratio for my '17 Camry.....Better ride than the 55 or lower aspect ratios.
Ya want some sidewall do ya ?
  • Like
Reactions: FZ1
