What is pcd and ET? The wheels are the same width, as they are both 8 inches wide. Center bore is just slightly larger on the newer wheels.centre bore and pcd the same? ET in the same ball park? clearance for the wider wheels ok?
Personally I think the wheels I am looking at will look great on the car.I'd be wearing of changing the wheel circumference. I'd be afraid it would make it drive goofy. Unless like you said get tires that will make it "think" it still has the 15's.
How will the newer style wheels match the older body styling? One of my friends put 350Z wheels on his 300ZX and I didn't think the styling matched at all.
Stud spacing should be the same according to a chart I found, it is the offset that I am not sure of. Also want the diameter of the tire and width of the tire to be as close as possible to the samepitch circle diameter, the stud spacing if you will. and ET is the offset of the wheel centre. You want to keep it as close to OEM as possible though on a RWD you can get away with a lot more.
Same here. In 07 I bought my rims with factory tires from a local in Tampa, FL. for $300. They're off of an 06 XLT.I'm a big fan of getting newer OEM wheels at a bargain, and using them to "wake up" an older model.
I paid $450 for these wheels and tires, from a 2015 Silverado LTZ. Stock for this truck was 16"... these are 18".
