rough idle when up to operating temp
hey
i have a 07 gmc sierra 1500 for the past year sometimes it will die at idle when warmed up not very often but it does but starts right back up and runs great when driving and towing and never stalls out, just put new plugs about 10,000 ago and doesn’t miss when towing or regular driving so the problem is only at a operating temp idle for about 10 mins it’s fine at top lights but when fully warmed up and idles for about 10 mins fully warmed it will either be rough idle or just stalls but start again immediately
advice
jacob
I was thinking about cleaning mass airflow sensor maybe engine isn’t getting enough air
Do you have a scan tool that can read live data? There's cheap ones out there, even a knock-off ELM327 reader would be useful in this situation.
EGR leak or IAC valve are two things that pop in my head right away. But without a code or any other data, we'd just be guessing or you'll be throwing parts at it hoping something sticks.
Similar issue. New engine. Runs rough at start up. Replaced coolant temp sensor, swapped out throttle body and EGR with used ones. Was all set to throw in an ECM. Friend scanned it at work; OBD1 scanner. Came up as MAP sensor, which should be the same as MAF in newer vehicles.
MAP and MAF are two different sensors regardless of vehicle age.
