It could be a partially clogged fuel injector. I used to have that problem when I was buying Arco gas. Switched to Costco Top Tier gas and after about 5 tank fulls, the idle returned to smooth.
The 2007 Ecotec seem to have dirty injector issues, nothing severe the flow and pattern seem to get screwed up easily with these units for some reason. I have seen them with low miles on them and had issues, one would vibrate when you let the clutch out, not smooth at all but idled fine.
OP. Try a full tank with a can of Berrymans Chemtool in it (put the Chemtool in first so it mixes) run it low without running out of fuel and then a bottle of Redline SI-1 (O’Reilly has it in stock) in a full tank. As long as no CEL is one I have a feeling you problem will help.
These are different chemicals for different issues no single product does it all well. The PEA takes care of carbon and hard deposits at the nozzle better than anything but varnish and other non hard deposits on the back side of the disc or pintel are better addressed by the Chemtool. A double prong approach that cost less then $20 is well worth a try IMO.
