i think that all rotors have stamped on them a minimum thickness. i believe that is the point at which that rotor can no longer be cut. however, isn't there a measurement at which a rotor is unsafe? i thought that was called the discard thickness but it seems some people use it as the cut number. so do rotors have a number at which that can no longer be safely used in a vehicle?
