Well it's time to change the brakes on the 2006 Grand Caravan. When I was reading reviews before buying this van, one of the major weak spots noted in this vehicle was brake life. So I've decided I'm definitely going to go with the ceramic brake pads. The point where I'm a little undecided is the rotors. There doesn't seem to be much information on rotors to indicate if any of them bould be better than others. Most of the rotors seem to be in the $30 each range. Advance has a wagner for $17 and a wearever for $32. Oriely has a BrakeBest for $32 and a Bosche quiet cast for $50. And Autozone has a Duralast Gold for $50 and duralast for $30. The only one that really claims to be anything special in the Duralst Gold which is described as being a high-carbon steel. Otherwise there doesn't seem to be any indication of quality other than the asumption that more money means more goodness. Any thoughts on which one's are going to have the best life span? Is the high-carbon steel really anything special?
