I made a mistake while replacing the rotors (Raybestos Element 3) on my Fit. The hold down screws were too corroded to remove so I drilled those out, but I forgot to remove the remnants (the threaded part). I bolted on the wheel and spun it around only to notice that it wouldn't rotate smoothly and binding at a certain spot. I tore back into it and discovered my error. It was only one side, the driver's side was done correctly after discovering my error, but I now have a nice little pulsation while braking.
Question: Did I warp the rotor by bolting it down onto the protruding thread?
