RotellaT6, 5812oci, 75084mi, Subaru Forester XT
Southeastern WI
This is my wife's Forester which is typically driven 12 miles each way on her commute. A few highway trips but nothing note-worthy. What concerns me is the silver in the sample- does anybody know if Subaru uses silver in their engines? I've run a few samples before on my Subarus and have never had it pop up. What gives?
I'm also going to keep an eye on the chromium to make sure it's not a piston ring on it's way out like I suspected on my Legacy
Code:
Rotella T6
Calcium 1050
Zinc 1188
Phosphorus 1019
Magnesium 1025
Boron 21
Molybdenum 61
Iron 16
Copper 3
Sodium 7
Silicon 12
Aluminum 5
Chromium 2
Potassium 3
Nickel 1
Lead 0
Tin 0
Manganese 0
Silver 8
Titanium 0
Barium 0
SUS @210F 69.0
cST @ 100C 12.69
Flashpoint 385
Mi on Oil 5812
Mi on Unit 75084
These may help you out:
Sources of Wear Metals in Oil Analysis
Oil Analysis Tests
Some have said (SubLGT, you out there?) that they' ve seen high silver prior to a turbo failure. I wouldn't be too concerned at this point, but would start to get a little more concerned if it doesn't drop on the next uoa.
I've also read where Subaru has stopped using lead in the bearing material, but don't know of they're using silver instead and don't remember the year they switched.
-Dennis
headgasket leak? IIRC rotella T has no potassium or sodium in it?
Possible impending turbo failure for the Silver?
edit: checked some VOA's seems like
the sodium is normal and the potassium should be
so really not showing much of a problem(if any) with those 2 elements.
They do recommend a 5w30, but running a thicker oil shouldn't be of any detriment to my engine's longevity.
Assuming this is a main bearing is there anything I can do to slow the wear down? At what point do I need to be concerned? 20ppm?
Originally Posted By: Eddie
I thought Subaru XT recomended a 5w30 oil viscosity.
5W-30 is preferred for fuel economy and 5W-40 is allowed down to -4F.
It appears that this Foz may be affected by the 08/09 Subaru turbo stop sale TSB.
-Dennis
