So at 2200 miles my 2007 FJR has the dreaded "sticky" clutch problem that seems to be unique to the 2007 models. The forums have been all over the place on solutions; the dealer says removing the clutch plates and soaking them in synthetic oil overnight cures it. Others have switched oil and others have bled the clutch line (it's hydraulic) or rebuilt the slave cylinder.
So after bleeding the clutch line, I decide to dump my load of Rotella T Synthetic and go back to dino. I had three qts of Castrol GTX 20w50 2005 vintage plus two qts of Castrol 20w50 4T mototcycle oil. Close enough... so in they go.
Comparing the Rotella T and the dino, the two differences I can feel are slightly more vibration on the dino plus maybe a bit sluggish. Both very slight... Clutch is performing much better, so I think I'll leave the dino in for a couple thousand miles and then switch back to the Rotella.
