Umm...so the TBN is kind of irrelevant if you're getting good wear numbers...which you are...better than the Mobil 1, or at least the same.
Here is my previous post, on same engine, on same oil, with WIX analysis:
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
Results are in for Shell Rotella Gas Truck 0W-20 in a 2013 Honda Civic (1.8L, non-turbo) From this earlier post I was looking for High Ca/High Moly oil: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5250127/1 I arrived at Shell Rotella Gas/Truck. It was also on rebate. Results are...www.bobistheoilguy.com
I'd keep doing what you're doing with RGT
The sample seems good. Nothing way out of whack that I see. You are correct that P & Zn do seem higher than other RGT UOA's.
The most shocking thing to me is the RGT TBN with only 2,400 miles more on the oil. The Mobil 1 could have gone a lot longer with a 7.3 rating, the 2.1 on the RGT is near the end of its life. What was the driver to go to RGT?
I'm not following. After 9K miles, the previous TBN was still 7.3?? That has to be a mistake.
Overall I'm happy, but curious what you guys think of the TBN 2.1 seams low compared to the Mobil 1 I ran before. Also phosphorus and zinc seam high to me when I compare this to other UOA of Rotella gas truck. Thanks
I adjusted the valves for the first time at 89K should have done it earlier. A few exhaust valves were tight.Thanks for posting.
I am very curious about how often the valves are adjusted,
as a used HRV is on my short list.
Great engine.
Be happy with this UOA.
I'm not sure if it was residual from zddp additives I've used in the past. (zddp plus and lucas zddp)I just did an oil sample of RGT 0W20 and didn't see zddp numbers like that. I ran my oil 4750. I think they might have gave you someone else's sample.
Typo I wrote 3.9 on the slip I shipped to the lab.Engine oil capacity is only 3.1 qts or is that a typo in the report? Thanks.
Normally takes exactly 4qts, I drain the filter even when I don't change it.I think that is incorrect, but it isn't far from that...maybe 3.9qts is what google says
Good to know about the TBN.I would not worry about TBN.
With a high quality synthetic such as RGT 0W20,
it would hover around 2 for a while.
Oxidative thickening is always my greater concern.
Yes it is an SN+, the calcium and zddp both seem elevated to me.Is that SN+? Calcium level is not what I would have expected.
Also that TBN for the M1 is similar to a VOA using the Hard Base Test. It's not what I would have expected after 9,000 mi.
