Rotella 10W-30, ok for cold temps?
NY
I'm just curious how well you guys think Rotella 10w30 will flow during the winter in NY. My Mustang Cobra (see a few threads below) will occasionly be started in low temps to be moved in/out of the garage (I'd say 10 degrees F would probably be about the lowest). If it's a concern I'll probably go to a lighter oil for the occasional winter start.
Thanks
Travis
0w-20 or 0w30 is better. wear comes from cold starts - 90% or more. Use a 0w-20 0w30 because the cST or centistokes are less. There is no perfect start up oil on earth unless it's it's aroung 100c. All oil's are bad at start up. Most have the same Vis. at normal engine temps !!
