Rotating Feathered tires
Minnesota
I have a car, 2010 Jetta, that has feathered tires on the rear. They are making a lot of noise. What would be the best way to rotate the tires to reduce the noise? I plan to sell the car in the next couple months so I don't care about what's best long term. Just want to reduce the tire noise.
Thanks
Do an X pattern. You are changing the tread blocks 180 degrees which will lower the tread noise for awhile. Report back here if it works.
Just an FYI:
Rotating the tires is going to make things worse! Temporarily. You need to give the tires some time to wear a new pattern.
But be aware that you may not be able to wear the old pattern out enough to make a difference. After all, the new pattern is being worn on top of the old pattern and may not erase the old pattern.
Originally Posted By: CapriRacer
Just an FYI:
That was my experience as well. My wife never rotated tires before I met her, so they had at least 20k on them. They were surprisingly silent on the highway. I decided to rotate them to try even out the wear, they were very loud at first, then slowly wore back to a more even pattern. I rotated them regularly for a while. It never got totally quiet again, but by the end of life, around 45k, they were much quieter, and the wear had evened out.
Well I rotated the tires in an X-pattern. When I rotated the tires I noticed that the tires were worse than I had originally thought. The 2 tires that were on the back were such junk that I just went to walmart and got a pair for $147 out the door. The car is so much quieter now!
I would normally not buy cheap tires from walmart but we are selling the car this summer so I really don't care.
Moral of the story, buy good tires and take care of them.
you can only rotate in an X pattern if the tyres aren't directional, so check this first.
I rotate twice per year, when going from winter to summer tyres and vice versa. But only front to back as I use directional tyres (standard fit were assymetrical)
