Rockauto Wholesaler Closeout
Kennett Square, PA
Rock had a great price on my Denso air filter due to a “wholesaler closeout”. Think I am safe buying this? I am visualizing a mangled box and filter. Thanks.
Wholesale closeout is a bit of a crapshoot, I tend to shy away from them for paper/rubber items because of the possibility of it being very old stock. You might get lucky though. Normally I've found that even the super cheap wholesale price + shipping is only 5-10 bucks away from a good filter so why risk it.
I normally order filters from RA 6 to 12 at a time . This spreads the shipping cost over more items . Knock on wood , I have come out OK , so far .
If you can get them cheap enough , you are not taking much of a chance . Especially if the price at Walmart is a fair amount higher .
  • Like
Reactions: JC1
I just ordered and installed these 4 shocks & the improvement way better. Got all 4 for $51 including shipping, can't beat that if your not in a hurry.
GABRIEL 61539 (Heavy Duty) ProGuard Info
Rear [Wholesaler Closeout -- 30 Day Warranty] Rockauto
GABRIEL 61555 (Heavy Duty) ProGuard Info
Front; RWD [Wholesaler Closeout -- 30 Day Warranty] Rock Auto
I expect those to be bad out of the box due to age.
I have had good luck with wholesale closeout. One time I bought a filter and the filter description was wrong on rock Auto. I did the refund process online and it was super easy and I got to keep the filter anyway. It was Amazon levels of easy to get a refund.
"Crapshoot" was the first word that came to my mind, but I've actually had good luck with RA closeouts. Five-dollar cabin filters for my Silverado turned out to be Carquest carbon filters, and I got a bunch of NAPA 11-inch wipers for $1.87 each.
I got a regular stock Denso air filter that looked defective once, though. It was a one-piece heat molded fiber filter for a Vibe/Matrix. The part that's supposed to seal against the airbox had material missing from one corner and seemed like it could leak. (RA made it right with no problems.)
I also ordered a full set of Gabriel for one of my cars... Boxes looked brand new and had no issues with them. Car is 20 years old, so if these last a few years, then money well spent even with shipping
  • Like
Reactions: JC1
The WC stuff I have gotten seems to usually be private-label stuff, often old stock. (I recall brakes branded Checker Auto Parts.)
I have had good luck with Rock Auto closeouts including oil filters. I get wipers from Ocean State Job Lots a local discount chain. Never have I gotten burned, it was all good to very good value for dollar. Your experience may vary.
I saw those deals and was going to get them and decided on KYB gas a just instead for my 05 Silverado. It carries a heavy load every day, full of survey equipment. Original 200k shocks were bad, but even the new ones felt kind of soft. I didn't realize how good they actually are until I emptied the truck and removed the cap and box liner and racking to get a body job done. It rides awesome with no load.
I would go with brakes or any part that's unlikely to go bad sitting, like everyone else is saying.
I have the KYB Gas-a-just installed on my Gen 1 Tundra TRD now, it drives like a dream now. The factory shocks were Bilsteins. Think of it this way your back is also 200k older than it was back then. Comfort matters. A lot.
Going to revive this thread instead of starting a new one. I mentioned in a previous post here I had bought struts that were wholesaler closeout and they were new in box and had no issues with them... Well the other day I bought a plate bracket as wholesaler closeout item, and to reduce shipping I stocked up on a some air and cabin filters, along with a hengst fuel filter which was also a wholesaler closeout item and happened to be coming from the same warehouse... at 11.20 CAD, I couldn't say no, the same filter from all the sources I have here in Canada retails around 35 CAD plus tax.
Well, I guess there's a reason it's a wholesaler closeout item... the filter came in a basic brown cardboard box, with no o ring inside, wrapped in a bunch of bubble wrap... it doesn't look used, and if it was, it would think it would reek of diesel (filter is for a 13 golf tdi)... see below for pics of the box it came in and a side by side of the same hengst filter that was ordered off RA aswell a while back, non wholesaler closeout, came in the proper box with an o ring. The filter on the right with o ring is original packaging, left is the wholesaler closeout
Will I use this filter in the future, not sure, on one hand it seems new, on the other, the thought of it coming in a generic box doesn't sit well with me
