+ 1This, you need to see the other side of the belt to check for cracking where the teeth meet the belt.
And put 1000 on car before taking it far from home.
3MZ-FE is interference.Is the engine a non-inference engine? That is, if the belt goes will one or more pistons crunch one or more valves? If it is an interference engine change it and the associated pulleys for peace of mind.
The OP said, in his second paragraph of his short post, that it's an interference engine.Is the engine a non-inference engine? That is, if the belt goes will one or more pistons crunch one or more valves? If it is an interference engine change it and the associated pulleys for peace of mind.
Ours was barely showing signs of dampness when I replaced it. Nothing was leaking, nothing was bad. I was surprised how good the old belt looked.On Honda's the hydraulic tensioner is the biggest issue -- they're always leaking long before the belt is even due.
This says change it to me3MZ-FE is interference.
Belt is 9 years old. We decided to take my little Scion instead. Better gas mileage anyways. I plan on changing the belt next month in a coworker’s garage.Here's my data point regarding Lexus timing belts. This belt was the original from my LS400. I took this photo in November 2021 (more for the timing mark location than the belt condition). The belt had 90,216 miles. Toyota recommends timing belt change every 72 months or 90k miles, whichever occurs first.
While it was at the mileage limit, 23 years = 276 months. 204 months delinquent.
The face of the belt looked like this. The toothed side looked fine. Would I do this again? Probably not.
Your belt will probably be OK for the trip. You're right at the mileage limit. How old is the belt (I'm assuming the present belt is original)?
Do you have the maintenance schedule for your RX?
The face of your belt looks OK; I would try to get a look at the toothed side.
I do know someone whose timing belt broke at about the time it was due for changing.p.s. just googled and I still can't find any documented cases where my car's timing belt broke and valves hit pistons, so likely again we informed folks worry about things that uninformed folks don't
