"VOA/used oil analysis prove nothing. I find that there are too many people relying on them. How does an analyis prove that there is less contaminents coating your engine? It doesn't. Only an inspection can prove that. A good filter can hide bad oil, and good oil could also hide bad filters. Engine condition can also throw off readings. Toss in driver style and IMO, analysis is overrated"
Additive brands aside;
undummy, I take issue with this quote for this reason, everyday, I ACCURATELY INTERPRET non invasive VOA/UOA, trended,ASTM,SAE testing. Have been for years.
PROPER INTERPRETATION IS THE KEY !
Simultaneously saving the same customer you charge $XX dollars an hour to tear into the engine or component for a cost much higher than $10 to $35 (each) I charge for a trended analysis.
If you are a professional mechanic please share your hourly fee and the total cost to scrape clean or teardown / reassembly charges that I can Identify and possibly chemically repair for pennies on your dollars of repair work.
Even when I find a mechanical problem that requires your expert services I save time and money by CORRECTLY and EFFICIENTLY diagnosing the problem.
NO, oil analysis isn't the answer for every issue or is it perfect but it is a very misunderstood tool that needs to be used by all technicians.
Another nifty aspect of oil analysis is that I can PREVENT AND PREDICT automotive problem symptoms before they cost $100's or $1000's .
There are quite a few of those happy customers on this board so I hope they chime in to share how effective and valuable a $35 oil analysis can be.
I have turned wrenches for years and started that way until the analysis business took over my Fleet repair business. I know what "work" is and salute your contaminated fingernails ! You aren't the only guy on this board that "works for a living" !
For instance Molekule has Advanced degrees in physics and chemistry and can turn a wrench with the best of any of us. He knows what he is talking about and can mathematically diagram it !!!!
He is the aviation equivalent of a TEST PILOT who has great flying skills ( a natural) and can do the math and science to properly express his Art. This is a rare breed and I count it a blessing and privalege to work with him on tribilogical issues related to lubricants !
Bob Winters is a pretty sharp mechanic too ! Types like me though !
One source of your frustration may be that not all that posts here are experts. They may be "learning outloud" or talking over their mechanical heads.
Most are trying to learn and this board was set up to air opinions, accurate and not. Stay with us and keep contributing and be prepared to have your opinions challenged but respected.
Sincerely, Terry
Sincerely, Terry
