I thought I would share some information on an Auto-Rx application, not particularly approved by Auto-Rx. I ran a maintenance dose without first cleaning and rinsing, oops.
The car is driven basically 50% highway and 50% city. I would also note that of the 50% city driving, 1 hour per day is stop and go, mostly stop. Driving environmental conditions are very dusty, gritty air. On the weekend my driving is usually short trips of less than 5 miles. I would consider this to be severe driving.
I had run PP for the first 25,000 KM. And have run Amsoil 0W20 to date. The oil analysis numbers on the left are from an extended drain on the Amsoil alone. The numbers on the right are of an extended drain with a 3 fluid ounce maintenance dose installed. I plan on running a couple more extended drains with the maintenance dose installed(approx. 15,000 miles). Then plan on running a longer interval with another UOA.
Canada Rob
Used Oil Analysis 3Fluid ounce Maintenance Dose
Dodge Caliber SXT 2.0 liter Dodge Caliber SXT 2.0 liter
Amsoil Synthetic SAE 0W20 Amsoil Synthetic SAE 0W20
With 3 fluid ounces of Auto-Rx
Full Flow Filter 15 micron Full Flow Filter 15 micron
Unit Time 85440 KM Unit Time 108,815 KM
Lube Time 25,140 KM(15,621 miles) Lube Time 23,375 KM(14,525 miles)
Wear Metals(ppm) Wear Metals(ppm)
Iron 15 Iron 9
Chromium 1 Chromium 0
Nickel 0 Nickel 0
Aluminum 2 Aluminum 1
Copper 2 Copper 0
Lead 0 Lead 0
Tin 1 Tin 1
Cadmium 0 Cadmium 0
Silver 0 Silver 0
Titanium 0 Titanium 0
Vanadium 0 Vanadium 0
Contaminant Metals (ppm) Contaminant Metals (ppm)
Silicon 31 Silicon 34
Sodium 17 Sodium 12
Potassium 2 Potassium 3
Multi Source Metals (ppm) Multi Source Metals (ppm)
Molybdenum 6 Molybdenum 1
Antimony 0 Antimony 0
Manganese 2 Manganese 0
Lithium 0 Lithium 2
Boron 19 Boron 7
Additive Metals (ppm) Additive Metals (ppm)
Magnesium 10 Magnesium 8
Calcium 2996 Calcium 2690
Barium 0 Barium 0
Phosphorus 520 Phosphorus 547
Zinc 635 Zinc 576
Fuel Volume Soot Water
Continued 2.0 liter Dodge Continued 2.0 liter Dodge
Amsoil 0W20 Synthetic Amsoil 0w20 with ARX 3 oz.
Viscosity 100C/ cs 11.4 Viscosity 100C/cs 12.7
TBN 2.38 TBN 7.76
Oxidation 44 Oxidation 29
Nitration 31 Nitration 21
Points of concern: Fairly high levels of Silicon found in both used oil analysis. A result of very dusty driving climate.
TBN low in the oil analysis from the run with Amsoil 0W20, run for 15,621 miles. TBN very stout on the run with the maintenance dose installed.
Viscosity higher than desirable in both runs. Higher in the run with the maintenance dose, likely due to cleaning of past deposits now suspended in the oil sample.
Points of improvement:
*Improvement in wear metal counts with ARX installed.
*Substantial reduction in oxidation and nitration with ARX installed.
*TBN remained stout on the run with ARX installed.
Canada Rob
Iron 15 Iron 9
Nickel 0 Nickel 0
Copper 2 Copper 0
Lead 0 Lead 0
Tin 1 Tin 1
Cadmium 0 Cadmium 0
Silver 0 Silver 0
Sodium 17 Sodium 12
Lithium 0 Lithium 2
Boron 19 Boron 7
Barium 0 Barium 0
Zinc 635 Zinc 576
TBN 2.38 TBN 7.76
