I noticed that Castrol makes hypoind gear oil that says nothing about differentials on it but says for use in manual transmissions. It has ZERO friction modifier additve in it and that got me thinking.
Most of the good brand name gear oils are formlated to include FM for LSD (limited slip diffs). There are a few that specifically say they are not for LSD, but most do. As you know, many manual transmissions and other gear boxes call for gear oil (such as 75w90, etc.).
The fact that Castrol's premium dino gear oil hypo-c (or something like that) only spoke of manual transmissions and not rear diffs and the fact it has no FM additive in it makes me think that when using gear oil in a manual transmission application, it is better to NOT use many of the more popular choices for rear diffs because they are all formualted for posi and maybe the FM additive is not good in anything else than a hypoid diff.
Otherwise why would Castrol dino 80w90 not have LSD additive?
I was buying gear oil for my front diff and I got the Valvoline conventional instead but I wanted to buy the Castrol but it seemed like it was specifically made for manual transmissions and not diffs.
discuss:
discuss:
