Right oil for BMW Valvetronic engine
EU
Hello everyone! This is my first topic/post here
I run 05` BMW 545i (N62 engine) and it`s time for an OC soon... The car has 91k miles on the clock and it does lots of short trips/idling. I want to use 0W-40 weight oil and it has to be BMW LL approved.
The oil needs to have good cold start capabilities (my valvetronic unit is very demanding to it), low oil consumption (I`m currently using Castrol Edge Sport 0W-40 and oil consumption is way beyond acceptional level - never had such problem with other branded oils) and good dispersant properties (also Castrol's weak point).
My OCI is 9k miles. I`m choosing between M1 New Life 0W-40 and Shell Helix Ultra 0W-40. Any comments and opinions on my choice? What would be your advice?
P.S. Sorry, if my english is a bit weird
Unfortunately Helix Ultra 0w-40 isn't sold in the U.S. The only well known 0w-40 in the U.S. is Mobil 1.
Personally with the short trips I would look at a 5w30 or 0w-30, but that's just me.
His location says "EU."
to BITOG!
For what it's worth, one of the pieces of accepted wisdom here is that the differences among approved oils in terms of wear protection are not likely to be significant. That's how the spec is designed.
If you have a favorite viscosity, that narrows things down a bit. As long as you're not looking to run your car in Antarctica or race it every day, pick your favorite bottle design and go with it.
Yea I wasn't clear in my comments. I should have ended with "so most on this forum can't comment about it'.
I was thinking that might be Eastern Utah, hence the comment about his English being "weird".
How would you know what someone from Eastern Utah sounds like? (My wife is from Roosevelt.)
I`m not sure, whether it's a good idea putting 30 weight oil in an engine with 91k miles... But on the other hand, it was filled with 0w30 ACEA A1 oil when new
And there isn`t much 0w30 oil with BMW LL approval out there on the market - GC, Aral Supertronic G (GC`s twin brother, with a slightly different additives) and Total Quartz Energy 9000 (the cheapest oil I can buy, but I have no experience with Total products).
As for M1 - I`m pretty sure, "New Life" is just a part of a brand name - it was added, since oil became API SM. So it must be very close to the M1 you get.
To be honest, I`m looking forward to hearing about Shell oil - is it any good in a BMW engine? It`s not popular at all in my country, so it`s kinda black-sheep to me.
It's fine. I have 30-weight oil in my engine at 163k miles and it's doing quite well -- even better than the 40-weights I've tried.
to BITOG!
Thank You!
That's why I`m more interested in oil`s compatibility with Valvetronic unit (cold start properties) and other stuff I mentioned earlier
As for Antarctica and racetrack - sometimes during winter, temperatures drops to -30 deg. C and I like to give it full throttle when I`m on a highway)))
I wish - everything is cheaper in US, than in Europe(((
Trust me, the modern synthetics you're looking at won't even flinch under that use.
Start talking about -60 C or CONSTANT full-throttle use at low-to-medium speeds, and then there might be something worth worrying about.
Choosing between 5w30 and 0W-40 - which is better at lower temps (from 0 to -20 deg. C.)?
Depends on the oil, really. 5w and 0w measurements are taken below that range so there's no way to tell just from the viscosity grades.
Try to get actual CCS and MRV numbers for the oils you're looking at, and go from there.
Thanks
I`ve come here for answers, but now I have even more questions :D
For a Euro 0w40 and a Euro 5w30 at those temps, generally and most of the time, the Euro 5w30 will be "better".
(For those in the US, he's talking about 0*F to 32*F)
This would be like comparing Mobil 1 0w40 to Mobil 1 ESP 5w30.
So you think, that Mobil 1 ESP 5w30 should "suit" me "better"? Is it good stuff? In comparison with Mobil 1 0W-40, what are the differences, except it being low saps oil?
I think he was only talking about cold temp performance. Mobil 1 ESP 5w30 and Mobil 1 0w-40 aren't really comparable oils.
Can you use a LL04 oil in your country?
