So I had failing original front struts on my 2004 Taurus with 70k and, with the Monroe 4 for 3 offer, decided to get Quick Struts installed on all 4 corners.
Prior to the install, I quickly measured the ride height. I was trying to establish whether to change the rears or not. They had been inspected and there was nothing wrong with them.
My front right was exactly at Ford spec. My front left was about a cm below this.
My rear right was exactly at Ford spec. My rear left was about 2cm below that.
Because the rear was also out of spec, I decided to go ahead with the rear install as well.
Well I got the car back, and the front left is a little lower than the front right, by less than half a cm.
But the rear left is still 2cm below the rear right.
I happened to have the old struts weighing in total 150lbs in the trunk, and verified that both left and right rear corners fell 1.3cm with that weight in. This matches the spring rating for the quick struts.
Any thoughts on whether a vehicle could inherently have a 2cm ride height difference between the right rear and left rear?
Or whether this has been caused by some kind of damage or other suspension component failure?
Would an alignment solve the problem?
Thanks!
Thanks!
