I would also point out that the 5W30 of today is far superior and more robust than the 5W30 of 1996 when you Aurora was built. A Mobil 1 5W30, if that is your choice of brand, can be run year round and for extended periods... both time and miles. IMO, depending on the operational cycle of the car which I don't know, you could run AT LEAST 7.5K miles and 2 years on a fill. Probably longer.
I have three passenger vehicles, all of which I have owned long term: an '86 F250 diesel (owned since '87 and 7K miles), a '00 Honda Accord (bought new with 7 miles) and a '05 F150 (bought in '08 with 7K miles). We put 5-7K annual miles on the two new rigs and 2-3 on the older one. Our maintenance schedule has slowly evolved out of a time based factor and is now done only by miles. The '05 Ford averages out to 18 months to 2.5 years per OCI (I recently extended it's mileage limit to 15K), the Honda to about 18 months (10K miles) and the old Ford is at an 8K interval and it's now at 5K 2 years into the run.
I didn't just arbitrarily decide to do this. I kept extending the OCI after used oil analysis and learn, or should I say proved what many experts say, that oil doesn't wear a watch. In reasonable periods of time, the oil doesn't deteriorate just from being in the crankcase. It's other factors that most influence the life of the oil, operational cycle, engine condition, environmental/storage conditions, etc. If you are storing the car in a good place and when it's drive , it isn't short hopped, rather it's driven long enough to fully warm it up and then operated a decent period beyond that, you are operating the car in a near optimal situation.
As to your proposed use of the filter, I concur with those who see no problem with it. Forgive my stepping past your question and pointing out what I see is a flaw and resource wastage with your current plan. If you do some searches in the used oil analysis section, you will find tests of 30 year old oil that tested as new, or used oil analysis on car with 1, 2, 3, 4, 5 ,6 year time intervals. Further reading will show what factors influence the life of the oil and for the most part, time is one of the lesser ones.
Stepping off the soapbox now!
