Rethinking grades: 5W-20 vs 0W-20
OH
I've been wondering recently whether I should continue with a 0W in our long out of warranty '12 Accord or go to a 5W.
We don't live in an areas where it ever gets cold enough that the 0W qualification would matter and there seem to be some advantages in a 5W-20 over a 0W-20.
When comparing oils of similar brand and quality, the 5W will always have lower volatility, which should help to prevent sticky rings over the years and miles. The 5W will also have a lower VII load, which should lead to less deposits over the years and miles.
Is there any real advantage in the 0W-20 grade?
I'm not sure that I can see one even though this grade is now widely recommended.
We recently purchased a 2015 PathFinder which specs 0W20, so I made up a batch of 5W20 HM and the engine runs smoother with better response.
Usually, the same engines in other countries specify that thicker oil should be used. For example, Honda indicates that the 0W-20 should be used in the J35 V-6 in the USA, however, the same engine in other countries calls for 5w30 viscosity oil. My certified Honda mechanic recommends to use the 5w30 for more protection, and this is what I'm planning to do in my 5W-20 specified Accord V-6 the next time I change my oil.
from reading it seems smaller spreads of viscosity is better especially with mineral oils, PAO + Ester oils are a truely different animal, but usually overkill for most typical drivers
I use 5w30 in most vehicles that call for 0/5w20. As said many cars in the US that call for thin oil call for 5w30 else where that does not have to meet CAFE standards.
My truck calls for 5w20 but I run a mix of 10w30/5w30, what ever I have in the shop.
I have pretty much the same thoughts as you concerning 5w-20 versus 0w-20.
I guess I didn't express my point clearly enough in my original post.
Everyone knows about CAFE, other market specs as well as that the engine won't know the difference.
I simply wonder whether I'm missing something in a market where all newer engines seem to have the 0W-20 grade recommended for them.
Nothing wrong with the 0W-20 grade, but going with a 5W-20 looks to me like all upside.
0w20 might have been specified to make sure you used synthetic. I'd think if you kept your 5w20 synthetic...no issues.
You formulated your own oil from scratch?
I bought into the 0W20 and 0W30 hype a few years back. The more I read up on it the happier I am that I swung back to 5w30 across the board. For my climate the 5W is a better choice imo for the reasons you stated. Unless you live in a very cold climate I think you're better off with 5w20 oil in your application.
Yes I’m betting he did.
Correct me if I am wrong, but shouldn't a 0- and 5w20 syn have about the same viscosity at operating temp? So the 0w & 5w part mainly matter on cold starts. Better flow on cold starts with a 0w20 is a plus, not-to-mention the better base stocks. I can understand avoiding 0w20 on an oil burner, though.
FWIW, my Pilot calls for 0w20 and that's what I plan on using indefinitely. Maybe as it gets older, I'll go to a HM 0w20 but that's it.
There is no real "better cold flow"... If it flows, the positive displacement pump moves the same amount in both cases.
Since we all lived OK for decades on 10w30 (even in OH), why even bother with the 5W ...
I usually use a 5w20 Quaker State Advanced Durability in the summer for my 07 Accord. Tbh, I need to burn some of my Quaker State Advanced Durability stash.
Never had, nor do I expect any issues from the 5w conventional. I just wish that QS hadn’t changed the formulation, but they are the experts..
Use what you want, it’s your car, drive and enjoy.
Yupper; that is when you can tell an old BITOG'r from a yung-un. Those who know mola can do that, and those who don't.
Absolutely he did.
He won't blow his own horn, too modest. Tribologist, and a host of other terms apply.
Guy is an oil guru, normal, honest, and a valuable contributor.
Respect and value his input.
We are lucky to have him.
Here is the link to Valvoline synthetic Maxlife product information. I just remember seeing it the other day. It shows a lower NOACK on the 0w20 than the 5w20.
Valvoline Product Information
I also always thought that 0w oil used better base stock. So hearing 5w is better is kind of new news to me. In what ways is it better?
