Working on what I think is a early 90's Honda 215SXA. Heavy aluminum deck, serial no. #6097432. Had to replace throttle cable, adjusted the others. Thing runs like a freaking bear! What appear to be original wheels, have very little wear, leads me to believe mower is low miles.
Next problem, is I can't get the transmission speed lever to move. Soaked the linkages/cable and such with blaster, to see if I could free things up. After a couple of hours soaking, speed lever moved, but with lots of resistance. It moved, but not without forcing it. Once oil dried up, lever is back to where I started.
I can see the actuator arm on trans jiggling up and down slightly as I try to move the lever, makes me think cable is ok, but something is jamming up in trans. Mower will propel forwards, and trans engages very quickly. Just can't make speed changes. Trans whines a bit when moving.
Thoughts? This is a very robust machine, I want to get this thing right!
