"RESTORE" Snake Oil>?
Atlanta, Ga.
I have a friend, trying to curb oil consumtion in his vehicle. Right now, he is trying Lucas Oil Stabilizer. After the information I found here, I suggested he not use it. Now he is asking for opinions on the product "RESTORE."
Personally, I would rather up oil weight, than throw an additive into the mix.
LOL!
there are many track-proven products posted on BITOG (LC/FP, AutoRx, etc.). Depends on how "Bad" your friend's oil burning situation is, you may be able to talk him into using one of these and see how things go.
p.s. If that car is buring oil excessively, my honest advice is to have the engine rebuild instead. No use running cleaners on a "neglicted" car...
What kind of car, engine, mileage, OCI, maint. history, etc., does your friend have? Knowing these things might help the good BITOGers to make a recommendation.
Maybe your friend could try a high-mileage oil & see if that helps with the consumption....just a thought.
As far as "Restore" goes, I used it multiple times, 7-8 years ago in my old '90 Mazda MX6 2.0L, when the engine had around 130k miles. I have no idea how it may have helped/harmed the engine. I think my Mazda was beyond help when I added "Restore". The Mazda was an oil burner/leaker & I drove it around low on oil frequently.
I believe that "Restore" definitely falls into the "snake oil" category here at BITOG.
About the only positive things I have heard about Restore, is that it temporarily quiets the noisy tappets in 1st Gen Acura Legend engines.
No one believes me when I tell them that running Delo 400 will do the same thing.
I tried Restore in my 1978 Chevy Van with the 350
and over 200,000 miles on it. The only problem I noticed was that I had worn valve guides and the
restore would run down in to the cylinders and
foul the spark plugs
quote:
Originally posted by Islandvic:
Is Restore the stuff in the black bottle?
Do they make the "Smoke-B-Gone" stuff?
Sounds familiar.
More like a silver can... Smoke-B-Gone is someone else...
my experience with restore....
I have an engine, that is probably the most infamous "ticker" on the planet... the 3.2L V6 found in isuzu troopers/rodeos honda passports, Opel MUs, jackaroos, etc etc (global equivalents)....
They have a non-adjustable hydrolic lifter arrangement. The "shims" (hydrolic lifters) wear out enough to start "tapping" back and forth somewhere around 150k for most of these engines. (my ticking started at about 148k, now have 173k on it)Ever since my tapping started I've been on an experimental rampage to find something that would quiet them down. (basically, needs to have some "cling" property to it, or be thick enough to bolster up the worn down parts, but at the same time not screw up the rest of the engine)...
Shortly after the ticking began, not understanding the design of the enguin- I thought it was a "sticky" lifter, so I did some "engine cleaner/flushes.(idle for 15 minuts with it in oil and then drain)" with each attempt the ticking got louder.
I found that STP had a very minimal effect, ran slightly quieter, running heavier weight oils has also quieted it down some.
MMO in the crankcase seemed to make it louder.
After taking a look at pictures of this type of engine and learning where the infamous tick was originating from, my results started to make since- heavier oils and addatives, could quiet down this type of problem, anything that cleaned off varnish (that previously served as a "bolster) or that thinned the oil made it louder.
Realizing the source of the sound, I was drawn to the claims by "restore" that it "fills" the gaps in worn down metals.
I was a half a quart low from burning (common on these engines also, even when much newer)... so decided rather than topping off with my regular oil, i'd throw it a dose of restore and see what happens.
(at this point, I was at about 155k, so I'd been ticking for ~7000 miles)
in 5 minuts I was sold. finally, silence. Litterally, in 5 minuts my tick was GONE. Within a week with this in the crank case I noticed reduced oil consumption and noticably better power.
continued my 2-3k change intervals, but included restore as a regular part of my changes every time. For ~10,000 miles, I was a happy camper with a silent engine again.
Then the ticking came back. even with the restore in the changes. Since ~165k, till now (173k) it's been ticking, and restore or no restore, it ticks. My oil consumption has gone back up and my power is back down. (though, some of the power loss latally may be the need for a new cat-converter)..
Here's what I'm thinking- Perhaps, "restore" will only "cling" to clean enguine parts, not varnished parts- so maybe If i did another "flush" (which I haven't done in over 20k), the retore might "work like a charm" again... or maybe it won't.
I can say, it definetally did something, for awhile. I should point out that- I have noticed a bit of carbon/sludge buiding up top. Might have been the restores fault (might also be from valave blowby, or again, too much backpressure from an old cat)...
In my opinion- it's not snake oil, but it's also nothing super special eithor. Might help a problem for a little while. But no addative can perminantly replace a worn out part.
my friend's 2000 Prelude was burning oil like crazy...we were driving once and this old guy pulled along side of us, rolled down his window and proceed to yell out "time to adjust your valves...look at that smoke!!"
then he tried Bardahl no smoke treatment, low and behold the oil burning has magically stopped...no more black smoke when his VTEC kicks in and the engine goes into the high lift mode.....
