I went with the smaller pulley, because it was the closest size available that fit on a 7/8” drive shaft that was available locally.
Had I known quite what I was doing, I would have ordered a pulley when I ordered the replacement motor.
This is the 3rd motor for this machine, so I don’t think the original info regarding the belt would apply. The OE motor was a Honda, the second (and now third) are both Subaru’s. I don’t know that the pulley on the previous Subaru came off the original Honda motor, or if it was added when the motor was swapped.
The motor directly tethers to the gearbox to drive the rear wheels via this belt. The belt that is on there almost fits. It’s able to transfer some of the motors spin to the transmission on the spreader, but even with the belt tensioner, it’s just slightly too loose to spin at the same rate, and therefor doesn’t give me the necessary torque to move forward without the belt slipping and overheating the pulley on the drive shaft.
Joshua, thank you! I had a feeling my math was too simple to be correct.
Just as an FYI, because I feel like the question is bound to come up: it went through 2 motors in 9 years because my predecessor didn’t believe in changing oil on OPE, or any other basic maintenance, so they got ran into the ground on their first fill, and then replaced. Though I started following the 50 hour OCI in the handbook, 4 years on its first fill surely did its damage. Anyway, the second motor bought the farm when a magnet came loose and made contact with the flywheel, shredding things as it fired out from the protective cover.
