A wooden double door is very heavy.
It's not that easy to lift a single door with a broken spring.
Get some strong back help, get it up and then prop it up with sturdy ladder or a piece of wood.
2X4 would work but 4X4 would be better.
If these are the kind of springs that run along the length of the tracks, replacement is pretty easy.
It might be best to replace both springs, since that will keep tension even on each side.
If one spring is notably stronger than the other, the rollers might bind in the tracks and the stronger of the springs will take a disproportionate part of the load and might fail early.
Also, if one has broken, the other won't be far behind.
Ask me how I know all of this about garage door lift springs
