I have a portable radio with a built in LiFePO battery, 7.4V 1000mAh it claims. The external power supply is 9V DC 1500 mAh and is used to run the radio on mains and charge the battery. The radio is rated at 15W, so the power supply is definitely not overkill.
The battery lasts about 2.5 hours with low speaker volume, but I could use 9-10 hours of use without charging.
I also have a surplus 20V 2000mAh battery for power tools, I would like to take 4 cells out of that and put them in the radio to get to 8V 4000 mAh (fully charged) and 7.3V discharged. The cells are LG 18650 HD2. That capacity should get me to about 10 hours. I use 20/40V batteries on all my tools so this one is the odd one that just sits and collects dust
What are the chances this will work with the built in charger? Obviously the charge current would be a bit lower than ideal but if that's an issue I could probably source a 9V 2500 mAh power supply.
I haven't opened the radio yet to check what it actually has inside, and won't if there's 0 chance this will work. Main concern is not starting fires!
