Replacement Tubing for Mityvac 7201 Fluid Extractor
Plus, the fact that it needs to be stiff to get down into engine/transmission pan.
I always hated wrestling with the curled tubing out of the box.
Now I store all three hoses in a piece of 3/4" pvc x 5 ft long.
Not that they straighten out completely when being used.
But while in storage, it shows them who's the boss.
I change my oil as hot as possible, then hang the tubing from the rafters in my garage. The heat straightens them and they drain into the pump. After they are done draining, I roll them up into a big circle and hang them on the wall.
They are typical industrial plastic line, so is that ¨sharkbite¨clip it slides into. This is industrial stuff and has been used for 20 some years....
the hose is designed for air and water, the connectors are ¨push to connect¨stye. Search for nylon tubing on McMaster Carr.
