Originally Posted By: mrdctaylor
Originally Posted By: nthach
I can't speak about a Toyota or a Hyundai since I never serviced one of their transmissions. I've seen a few transmission filters plugged up enough to cause problems, in Ford and GM applications.
Toyota has been using the same felt media filters as the domestics since the early 2000s. Filtran makes the FWD ones, while the one in my parent's LS430 was made by Toko Roki.
Looks like the simple screen Toyota(and Aisin AW) has been using doesn't cut the mustard for 5-8 speed transmissions.
Or it could be that they now claim Toyota WS is a lifetime fluid. If they went back to recommending ATF changes they might be able to go back to screens. Who knows. Regardless, I'm going to stick to 30k-50k drain/fill schedules for my Toyotas and don't plan to replace filters.
Having said all of that, when my daughter got my parents' 2002 Chevy at 150K miles, I knew they had never serviced the transmission. So I dropped the pan and changed the filter. The filter media looked just fine. I don't think it was necessary and I won't do it again on this vehicle. After that initial filter replacement/refill, I did another couple of drains/fills using a fluid extractor. 4-5 years later we're at 175k miles and everything is still running great.
I suppose I'd try a filter replacement if a vehicle was showing symptoms. Other than that, I don't see it as being a necessary preventative measure on modern cars. Maybe that's just me...
I'd rather not wait for symptoms, but I'm talking domestics here. If I hadn't seen and fixed a few problems first hand over the years with plugged up filters in domestic applications maybe I'd see it differently. My Jeeps will get pan drops, fluid and filter changes, along with fluid exchanges as long as I continue to own and maintain them.
As I said I can't comment about Toyota, I never owned one or serviced one. I figure if it has a screen or filter and the pan is down I'm changing it.
