Originally Posted By: xfactor9
Originally Posted By: CapriRacer
As I explained above, a 100% nitrogen filled tires is subjected to a 3.1 psi oxygen pressure from the outside.
A 100% air filled tire at 30 psi is subjected to 6.3 psi oxygen pressure from the inside. Even at 35 psi, the oxygen pressure is only 7.4 psi.
Does this mean that for long-term storage, it's better to place the car on stands and deflate the tires?
Sort of.
When a tire gets inflated with air, the oxygen permeates out faster than the nitrogen. What that means is the percent oxygen inside the air chamber gradually goes down.
Adding air to boost the pressure back up, increases the oxygen content, but only a little.
- BUT -
If you completely deflate a tire, then refill it later, the air inside the air chamber is now back up to the starting percentage. There's a point where doing this has a more detrimental affect than merely leaving things alone.
I tried to find a paper that Dr. John Daws wrote up - and I think it is here:
Nitrogen Inflation for Passenger Car and Light Truck Tires
He also has a spreadsheet that help:
Tire Air vs Nitrogen Permeation Simulation
The key issue that is missing here is the affect oxygen has on a tire that is NOT inflated. But Dr. Daws did make one important point and that was deflating a tire then refilling it (like you would do with winter tires) was one of the worst things you could do. You would be repeatedly adding fully oxygenated air back into the air chamber.
If I am reading this right, there is almost no scenario where deflating a tire for long term storage is better.
Plus, the way you asked the question, you would either want to get the car off the tires, or roll the vehicle forward a foot every month to prevent flat spots.
Then what about inflating the tires to 60 psi with air to prevent flat spots? That also seems counter productive from the tire degradation point of view.
I think the bottomline is that nitrogen can slow down the rate of deterioration, but not a lot. If you can get nitrogen for free, use it. If not, don't worry yourself about it.
