Replace rear calipers--now spongy pedal
Just a little tip on pedal bleeding: exercise caution if the master cylinder is older or the vehicle has a lot of miles on it. It's better to pressure bleed those examples.
Otherwise, pedal bleeding can damage the seals on the MC as it runs them past their established range of travel and over the cylinder wear ridges. Letting the booster kick in only makes it worse. It makes for an unhappy ending to the job.
