If the crank is slower, would you consider this more of an indication of a dying battery over the technical checks?
So the past 2 weeks the starter has cranked slower than it did previously. Car still starts but I thought I should look into a new battery. Pulled out my owners manual and it states a reading of 12.8 - 12.9V the battery is considered charged. So I drive to the store to look at batteries and after 20 minutes I go outside to check the voltage (as per manual) and is bouncing between 12.9 and 13. Decided against the new battery since I left the tools at home. Check the V again and it was at 12.9. This morning it was again 12.9. Btw, the eye indicates the battery is good.
Battery is 6 years old
Operated in a year round warm climate
Manual states any voltage below 12.6 = replace battery
